I knew that I should have left it alone.:( I went out to the shed with the intention of putting on my new foot pegs and calling it a night.
But NOOOO! I decided that tonight would be a great night to replace the fluid in the front brakes.:mad: Please bear in mind that the brakes have worked fine for the last year and a couple of months without my intervention.
I had been wanting to change the fluid for awhile now. Well, last week I finally got the two screws on the master cylinder loose(without ruining them:))
That's about where my luck changes for the worse. When I started I had working front brakes.
Now, I got nuthin'.
Let me describe what I see and you guys/gals can shoot me some suggestions.
I don't know what type of fluid was in the brake system when I started. All I know was that it was brown. The bike calls for DOT 3 or 4(what's the difference in these anyway?) I used DOT 3.
When I pull in the brake lever(with the resevior full) and open the bleader, I get nothing but fluid. For the first few pumps I could see the fluid advancing down the blead tube. So far so good. Or so it seems.
It was about then that I lost all feel in the brake lever.
I notice that there is a small air bubble in the resevior. A couple of taps on the side of the master cylinder takes care of that. More show up. The fluid level never drops either.
How in gods name can there be enough of a seal for the piston to work one minute, and the next nothing at all.
Are there any other parts to the brake cylinder that I can check? All I see is two rubber seals on a shaft and a spring. Are there any other components in the housing that can be checked?
Help.
Now, I got nuthin'.
Help.
