Mully
Moderator / SuperPowers
- Jun 9, 1999
- 4,234
- 115
Ok, so I didn't finish the Jackpine Sunday. Something about a stump and a gear shifter meeting each other on bad terms. The shifter bolt has snapped completely off inside the shift shaft. Can someone tell me what method they would use to remove the remaining bolt???? The remaining bolt is below the surface of the shift shaft.
Center punch the bolt, drill out the center, then use an extractor????? Never have used one, any gotchas to watch for??
