ochster
- Mar 11, 2000
- 689
- 0
A recent cam I did, actually showed to be out of spec, by near 6-7 degrees. This difference was actually between the intake opening and closing specs. I merely split the difference, and preceded.
Was just curious, if this is common? I'm figuring it to be either a slight change on the cam manufacturer parts, and not wanting to change all kinds of printed specs. And or, the simple reality, that the final product may not have been made to print.
In this particular application, the cam sprocket was slotted. It was equally machined on both sides of the oem 6mm hole (slot). Even after splitting the difference in lobe spec, my final setting ended up a couple thousand from one side of the slot.
