FrankD247
4
So I broke the kick start shaft. I took everything apart, replaced the kick start shaft. Put everything back together, put in new fluids.The motor kicks over fine. The motorcycle wants to start. I have a suspicion that it has something to do with the governer. I did not make sure everything was lined up properly. Any insights???? :|
jackflack44
490
spark plug? or try holding the throttle 1/8 to 1/4th open and then kick.
FrankD247
4
no spark plug is fine, i have tried all the simple explanations. carburetor and jets are fine, aircleaner is good, mix is fine. it has something to do with the repair because it was running fine before the fix.
