Magellan
193
This is the nut on the end of the crank that holds the gear that drives the clutch basket.
The nut spins, it just doesn't back off the shaft. I used an impact to get it lose...maybe I stripped it, though I've never had that happen before. It doesn't tighten either...just spins.
So, now I need ideas on how to get it off. Pretty close quarters for a grinder. I can probably get a dremel in there.
I'm hoping I just stripped the nut and not the shaft.
ugh....
mag.
Magellan
193
Solved
I couldn't leave it alone and solved my own problem.
I ended up using the grinder. I ground down to opposite points to as close to the shaft as I dared.
I just started the cut with the grinder, then finished the cut with a hacksaw.
I then just grabbed both ends with vice grips and "peeled" the nut open.
Fortunately, the threads on the shaft are fine!
In the following pic, I put the nut back on the shaft to take the picture. It was still solid all the way around after I made the cuts:
nut ground
Nut Removed
