The bike will not idle at all. You have to twist the throttle almost 1/4 to get it to idle. I was thinking maybe the needle jet needed to be moved to a higher slot. The throttle cable has some slack in it also and it is adjusted all the way out. I orded a new cable but do not belive that it is the problem. Otherwise the bike runs great. Are there any carb gurus that can help me. Thanks
