SuzookKING
82
I am swapping a Keihin 28mm round slide carb for a Mikuni 28mm flatslide, is there some sort of corelation between the jet sizes on the 2 carbs.
In other words, if I am using a 130main/52.5pilot in the Keihin, what would be a good starting point for the new Mikuni carb?
Jman271
317
You should be close, I did the same thing for my sons CR80, and used the same jets, it worked great. I had a 127/125 main in the flatslide. Good luck-
SuzookKING
82
This is what came in the new carburetor:
Mikuni VM28-418
28mm
180 Main Jet (4/042)
15 pilot Jet (VM22/210)
175 P-8 Needle Jet
5DP39 Jet Needle
832-33001 2.5 Throttle Valve
We have put an identicle carburetor on a Derbi GPR 50cc and it took a 170 main jet for extended WOT usage.
DEANSFASTWAY
1,192
Usually the Mikuni # is like2xs larger dont just swap straight across or it will be too lean and youll possibly burn down. I think there is a coversion chart somewhere .Maybe do a search as I think I saw something here before .
Mikuni hex head jets are numbered by bulk flow, while Mikuni round head jets are numbered by inner diameter in mm.
The flow difference between a Mikuni 175 hex jet and a 180 is about 6cc ~3%) .
Keihn jets are numbered by jet id, and the difference between a 178 and a 180 is about .0008" .
I don't remember if the VM28s use round or hex head jets.
Basic math looks like this:
weight of fuel = jet area * ( SQR Root (head pressure * fuel density) )
