Marcus, I saw your picture showing what not to do when drilling out the peens. Can you explain it a bit more. I'm totally new to this and think I may have done the wrong thing. To drill the peens out I used a small drill bit and drilled until I could see the outter tube inside edge against the part that unscrews from the outter tube. Anyway, how much heat do I need to apply. The oil is smoking and I am worried to apply too much heat for too long.. HELP and THANKS
