Hi Everyone, 3 weeks ago i bought a 2001 CR250R after 3 rides the chain had stretched a little, and one of my friends told me I should tighten it up, so while trying to tighten it up i noticed the adjuster on the side of the sprocket was very hard to turn, and the nut was stripped, so i decided to buy another.
Well tonight I was going to change the two nuts and bolts,
while undoing the one that was hard to turn, the bolt snapped off, so we tried to drill it out, with no luck, everything was going good, then the drill started to go off center and cutting into the aluminum of the swingarm. :bang:
Now I'm stuck, I guess an option is to remove the swingarm, drill the hole out bigger, tap it and insert a helicoil...
Anyone have any other idea's?
Tom
Tom
