kxmike
65
i know this is probably the most stupidest question but ill ask anyway. i have a 2003 kx125 and it has 112 links on the chain. i am ordering a renthal r3 works o-ring chain and it comes in a 114 link. do i get that or what? :bang: thanks you and sorry
KX02
781
Yes, and then have one link removed from it. A word of CAUTION. I put an X ring chain on my KX and I had clearance problems both at the case and the rear chain guard. I ended up using a dremel to remove a little bit of material from the case to get the wider chain to fit.
