eric311
13
how do you figure what size chain you need. I know what stock is but how do I determine what I need if I go with a little deferent sprockets. thanks
490Dave
316
Need more information.........
Chain size, 420, 520, 530 etc...... depends on the bike size and sprokets you use.
Chain length, again depends on the bike, gearing, length between sprokets etc.....
Not sure about formula's or a "rule of thumb" you can use. Most sproket manufacturers will offer gearing charts and chain length info on their web sites.
eric311
13
it is an 04 crf 450 and i plan on using a 13 front and a 50 rear. stock is 13 48 do i just add 2 links to that to get the correct chain. any recomendations on the gearing or chain
IndyMX
Crash Test Dummy
5,548
Amo, IN
Most places will sell you around 120 links, standard..
This will be a few links longer than you need. Setup your bike how you like the rear wheel, and measure your chain, then cut the excess links out. Be careful so as to not remove too many links.
It's not rocket science.. Simple counting will do.
