If you use 15/45 gearing you get a resultant ratio of 3.00:1. 14/42 gearing will get that same 3.00:1 ratio.
Will both of those setups actually get you the same net results? Is there any difference at all between the two setups?
I only chose those sprocket combinations as examples because the math is easy. I don't think I need to go that fast.
