can anyone help i av a xr650 the trouble is when i pull the clutch lever in and put it in first the bike wants to go,ive been told that with the 2000 model its a problem with a bush or something.......
is the clutch lever adjusted properly? is there alot of play in it? Sometimes the cable stretches and the lever needs to be tightened back up. even if you pull it all the way back to the bars the clutch is still grabbing.
