a little trick i use to do on my open bikes is to either lay them over till gas runs out the over flow of the carb, or put it in 2 or 3 gear and rock it back and forth (charging the cylinder with fuel) my KX would start 1st or 2nd kick every time. the Cr I had would also start couple kicks.
