DRTYMEX
11
Ordered a new service manual for the yz and should be in around next week. WEEE! But in the mean while, was doing a compression check and bad news, it's low (90psi). :(
Just out of curiosity, what is the spec psi as per the yamaha manual?
Looks like several things I need to look for. Is there a history of cdi problems on the yamaha's?? Or flywheel magneto? (forgive me, I don't have my manual yet)
Bike is farting while kick starting and sounds like it's the ignition. Started with cleaning the carbs out, and that seems to be all right.
Buying a used bike sucks butt, especially without the service manual. Oh well, any topend rebuild kits you recommend for the yz 250?
Rcannon
1,886
Altitude makes quite a difference with compression...Here in Utah, 180 is a high number. 90 is not going to cut it in any location. Rebuild the top end before you worry much about the farting.
bedell99
788
At sea level at least 180psi, wow that is low. remember when doing a compression check kickstart the engine at least 5 to 10 times quickly at try to leave the piston on the compression stroke and then read. If you do it right you will see how much leakage is coming from your rings. If it is at top dead center.
Erik
Rcannon
1,886
Here is the funny thing. In the time it took to post the answers we could have had the rings changed out on your bike.
This is about the time your going to start giving yourself big bear hugs for buying a two stroke.
By your third or 4 the top end, you can complete them in slightly over 1 hour (assuming all the parts are in the garage). The process is not worth worrying about.
I did my last cr 85 in way under an hour. Thje little bikes give you a lot of practice. My Yz 250 woudl take under 2 hours.
chalie
41
After about 6 kicks on my 2001 kx250 i got a max of 220psig
I have more than 55hr on topend too, but all trails, so she's not been beaten up too badly. Hope this helps. :cool:
