elephant35e
- Nov 14, 2012
- 7
- 0
ok, so awhile ago i did a compression check properly, thorttle wide open, engine warm, and kicked it pretty hard and it read 92 psi. i heard 125cc 2 strokes needed 160 - 180 so i figured out i needed new rings. well i took the head off and it looks like the rings aren't really worn. could they be worn even thought they don't look like it? or could other things cause low compression? if so, what? the o-rings on the head didn't look worn either.
if ths helps, its a 2002 yz125.
