phranticness
134
what are you trying to accomplish with more low end...........If you trail ride I've found the quick and easy patch is to go with lower gearing. Usually I go one smaller on the front sprocket, that is too low for most people. just perfect for me...........front sprocket retails for under $20.00
94formy
68
low end power and 125's don't go hand in hand. If you want to stay on a 2 stroke then the best way to get more low end power is to go to a 250.
robwbright
2,283
A 144 overbore will seemingly add 15-20% everywhere, but it won't really increase the low end of the power spread.
A flywheel weight will help a little bit - at the sacrifice of "hit" and some quick revving. I'm currently running an 11 oz.
The gearing changes are very effective at helping give a little bit of low end.
Get a 250 if you need more than that - either the 250 2 stroke or go over to the dark side. . . LOL
