cmac_attack
- Jul 21, 2006
- 7
- 0
You guys are simply genius on here. I got another one for you to figure out. I have a 1994 CR125 that i recently rebuilt i.e. bearings in bottom end and new top end. It starts perfectly on first kick everytime. revs perfect in neutral. When i shift to first and clutch still pulled, sounds excellent. BUT, when i start to release the clutch and barely start moving, there is a high pitched "whirring" sound from the engine. It gets higher pitched and louder with the throttle movement. It is also in second gear. Third fear and so on just drown out the sound! ANY help would be much appreciated. Thanks!
