mena
I Have Just Replaced The Fork Seals In My 2000 Cr250. How Much Oil Do I Put In The Fork Outer, And The Fork Damper In The Fork Top.also Do I Need To Bleed The Damper For Air.
darringer
1,029
Stock oil volume in the outer chamber is 386cc. The fork damper should have 180cc, and be 5-10mm above the ledge inside the damper. And yes, you MUST bleed the air from them.
