tstapp said:Can anyone give me some advise. I had my 1984 CR500R opened up on a stretch the other day and it lost all compression. Does the air cooled 500 have a problem burning a hole thru the piston? :think:
whenfoxforks-ruled said:Nope, but you do. That hole got in there from either detonation or an air leak. Even slight mechanical up keep could have prevented this. Been running regular gas? Check the plug, listen to the motor. The old 500 is about indestructible, can last seasons without top ends. BUT,,, it could have been worse. Vintage Bob
FYI, most of this type of information comes from guy talk and magazines like mx action and such. Waste of time, completely. Less you feel up for a laugh? Some may be true, I would bet that a modification to the cylinder/piston would resolve this also. But there is always a first? (30 seconds later) Not this time either, sorry. Its hard to get out of that habit, but it can be done. It worked for me! In Eric's book about MX and Offroad Performance Handbook, clearly states the issue and solution on page 177. Not 1 word about chronic overheating by the way. You made me get the book! Vintage Bobtstapp said:FYI... The 1984 Cr500R did have a problem with overheating, that is why after 1984 all Cr500's are liquid cooled. A small amount of research on your part would have revealed this. I do agree with you on one point, the bike is almost indestructible since I have been riding it for the past 15 years balls to the wall without any problems other than a few broken bones. Thank you for the advise.
