P pdm56 Member Oct 11, 2001 4 0 Oct 28, 2001 #1 What is a good pipe for this bike. Like to get a little more low end to mid. Also for a 150# rider, no equipment. What rear sprocket? 56 or 57.
B Buzz Bomb Member May 9, 2000 706 0 Oct 28, 2001 #2 It will never have a lot of low to mid, but the PC pipe helps out. It did on my friends CR80 at least.
Y yardpro Gone Bye-Bye Oct 15, 2001 529 0 Oct 29, 2001 #3 most pipes are designed for mid-top end perormance. adding low end is ?. Sprocket changes will do the trick, but they also shorten gears so don't overdo it. at 150lbs you should really consider a 125. oh yea also a 105 kit will make is scream.
