I have just nicely assembled the bike with an Athena 100mm cylinder kit and a Falicon 4.3mm stroked crank.
I have been trying to get the motor to start, very unsuccessfully. I have checked the TDC marks and both cam and crank are aligned. The motor is running approx. 12.6 to 1 compression ratio up from 12 to 1, so I reduced the clearance on the auto decompressor from the 450 setting of 0.63mm to 0.55mm. The motor fired to life for about three revs of the crank and stalled.
I am not sure whet the problem. I think it stems from increased compression and incorrect jetting. Do I need to jet richer or leaner? Will this have help with the starting. Is reducing the clearance on the auto decompressor a step in the right direction. I would appreciate any help.
In anycase I will keep you posted once I have ridden it and as to the reliability issues.
