polle
this is good setup mx crf250r 2005.Spring 0.42 and 2.2 ICS
comp.
30.1 x 14
27.1
30.1 x 2
29.1
28.1 x 2
26.1
24.1
23.1
22.1
21.1
20.1
18.1
30.5 x 2mm
Active:
08x 20.1x4 stock +2x20.1
17.1 x 4
9.5 x .2 x 1
10.2 x 2
2mm Post
Float .2mm
rebound
20.1
19.1
18.1
12.1
16.1
14.1
13.1
12.1
11.2
16.3 x 3
marcusgunby
6,450
Thanks for sharing your stack, What weight of rider is this aimed at, and what did you feel was the main problems with the std fork?
polle
I weight is 67kg=147lbs (with out gear).Stock fork feel harsh over braking bumps/ small chop and bike understeers.Clicker setting comp.4-8 and reb.12-18.stock valving.
FRESH VIDEO
