JTT
1,407
I am occassionally towing my 6x10 trailer with my "company car"...a 2001 Buick Century. It tows alright, but the rear end squats alot under the tongue weight. If I shift the weight off the tongue too much the trailer gets too "bouncy".
I was thinking of trying those little "Spring booster" things, that basically isolate a couple of the coils in the rear spring, effictively shortening them and therefore making them stiffer. Has anyone ever used these things?
I know the "right way" would be to use air type shocks, but as I said, this is not my car and I will only have it for a short time before replacement. Basically I am looking for a cheap way around the problem...or I could just ignore it ;)
Zerotact
1,001
If your car has rear coil springs, the auto parts stores have spacers you can wedge in there and kep the spring from collapsing. You could also load the trailer with the weight on the other end to try and even the load out.... Also stiffer/new rear shocks help a little.......
Fark
438
How about air bags, the kind drag racers use. Drop out the rear coil springs and put the bags in there. Inflate when towing. Prolly $50 for both.
JTT
1,407
Thanks for the help guys, but I guess I'll just leave it alone. I'll be turning the car in in the fall anyways, but may put the suggestions to work on the new ride for next year.
lawman
762
i had a shop install a booster system in an explorer that i was using to haul a bike on a moto jack. cost about $70, worked great--even made the car handle better unloaded, took out some of the wallow.
