2000 RM125. Lost the bottom end and now have several gouges on the cylinder walls (needle bearings bouncing around). Can they be filled-in and have the cylinder replated or should I buy a new cylinder?
buy new -expensive
have it bored and put a steel sleeve in it - heat disapation and the longevity of the sleeve are suspect
have it welded rebored to a stock size and plated cheaper and /or longer wearing than the first two options
have it overbored and replated witha bigger piston fitted possibley cheaper than having it welded and rebored plus more displacement more power. this would be the option I would seriosly look at.
Yeah and youll get more bottom /mid power . Most of the time when I build a bigger bore 125 I like to use a Yamaha type top bearing as it is 2mms wider than a Honda type and spreads the load better. 58mm 4mm oversize piston needs the cases opened up in the front a bit for clearance so dont assemble the bottom end before you decide what to build .
