robwbright
- Apr 8, 2005
- 2,283
- 0
I recently did the top end in my 2002 RM 125. The cylinder measured .0004 (4 ten thousandths) out of spec front to back and side to side - i.e. its a bit bigger than it should be according to the Suzuki manual.
There was about 1/8 inch of "blowby" on the piston below the ring. I don't know if this was caused by the cylinder wear or ring wear since the top end hadn't been done for 7 races.
Anyway, is the fact that the cylinder is .0004 out of spec a serious problem? The bike still runs good and seems to have good compression . . .
By the way, we used a tool dad brought home from the power plant - I'm not sure what its called. Shaped like a "T" handle with two spring loaded arms that pop out when released. Then you lock it, pul it out and measure with the accompanying gauge. We were able to get about 1 1/2 to 2 inches into the cylinder.
Rob
Rob
