Bike is an 07 144SX. Motor was freshly rebuilt.....first ride. Coolant bleed bolt located in cylinder head was not secured properly. All fluid pumped out of motor and piston seized. Pulled top end to find trashed piston and some scoring within the cylinder; below the transfer and exhaust ports. Reassembled top end with new piston. Motor seems to run fine but don't know for sure what the impact of the cylinder scoring in this location would be. The cylinder looks fine above the exhaust port. Would there be a performance impact if the ring seal below the ports is not perfect?
