say for instance you were between sping rates on your front forks, and no aftermarket company you could find had your spiecific spring rate. would it work to put one rate higher and one rate lower in each side of the fork, so it averaged out? i mean both forks are connected at the top and bottom. so its not like they will move are different rates? does this make sense? the guy at the shop i go to does suspension. and he claims this is so... any input?
