I have a 1990 kdx200 I bought used and ohmy was it rich.
elevation is about 200 ft above sea level
temperature is between 70 and 90 in summer
now between 35 and 50
when I got it it ran like a diesel found out the power valves were time incorrectly so I fixed them but my real prob is this
it has always sounded like a twin cylinder running on 1 cylinder and until I raised the needle one clip it sounded like flooded cat no ping and smoked like a train.
now once warm it mildly smokes but not to bad by the way it is white but my crankcase oil levels never drop.
But my question is I am pretty sure that is rich symptoms but when I installed fmf gold and fmf turbine it got even worse thats when I dropped the clip from the stock 4th to the 3 position.I want to make the jetting changes mentioned on the site but I had to lean it out greatly just for it to ping like a 2 stroke.And right now on the pilot circuit it still sputters and sounds like the above mentioned twin cylinder running on 1 cylinder.
the jetting recomendations say to make them richer then what I have does that leaner needle that is recommended going to lean those richer jets that much or do I have a oddball bike here.In the 1/4 to full throttle it pulls really good and hard but still smokes just slightly but the pilot circuit doesnt bog just sputters the jetting by the way on this bike is the stock r1172 needle and the 150 main and the 42 pilot
that is why I seem to be confused. oh I also have the air filter cover off.
any help greatly appreciated.I would not even post this if it did not seem to go against everything else I have seen and read.
