Originally posted by KawieKX125
I doubt wax removes scratches. Might have been buffing compound or plastic polich though.
The heat must have melted the plastic a bit and then took the scratches out,
Originally posted by Old CR goat
If this is your first time with the buffer, be very careful. Not hard at all to burn or discolor plastic, by the time you notice it is happening guess what,--too late.
Was should have no grit in it at all,
Originally posted by JMD
Another way to check if there's any grit is to take a tiny little bit of the stuff and put it right up your . . . well, never mind. I guess your mouth will work fine.
I doubt I can make my fender worse. Mine looks like some crazed chef attcked it with a very sharp cheeze grater. The fender is, err, fuzzy in a way.Kawie, you might want to start on an old fender until you get the hang of it.
Originally posted by TONY78
. I wouldn't recomend leaving the gun on the same spot for too long, but give it a go, you may be suprized how well it works.
Originally posted by gremlin
SAFETY NOTE HERE GUYS moping at high speed on plastic produces STATIC, empty the gas out first, if you are going to do the tank..
Another point, polypropalene melts at around 160 C and it doesnt take long to get there, so be careful..
