When using Wiseco pistons it states that you have to drill the 3 holes in the piston to provide adequate lubrication to the exhaust bridge. I recently experienced a meltdown on a 1987 CR 500 that is setup for hill racing and has had some series port work done for improved top end. I bought the 500 last year and put maybe 3 hours on it before it lost compression and at first I thought it had a bad crank seal but the piston was a Wiseco and was not drilled when the motor was built for the previous owner. The shop where I took the cylinder to be bored said it had been sleeved and was out 15 thousands on the exhaust side. My question is this " Can not drilling the holes in the piston cause a meltdown where the exhaust side of the piston is melted and the cylinder wall on the exhaust side shows excessive wear or do I have other problems that may have to do with the porting that was done on the cylinder?"
Thanks,
Jim
Thanks,
Jim
