Got a 2003 drz 110 for my son for Christmas, bike idles fine and seems to run fine. I havent had the chance to really ride it on the dirt yet so Im not sure its getting warmed up all the way but I dont think it should do what its doing.
Again this is when not fully warm, but if you crack the throttle it has a tendency to stutter, if you open the throttle wide open from idle it will either stutter as it tries to rev up(but does rev out in a sec or two), or it will stall out completely.
Last night I went through and cleaned the air filter, air box, cleaned up the carb., and changed the oil.. it seems better than it was before but it didnt solve the problem.
I am unsure of the condition of the fuel in the bike.. I pulled the plug and while it wasnt new it didnt look damaged or anything, o-ring type seal on the carb float bowl looked pretty flat, possible air leak there?- would it cause this condition?
Anything else I should look at? any ideas appreciated.
