effects under bad weather cond.
tolga
23
My Husa does not like water at all. First, the digital speedometer is gone. Meaning; that it resets itself couple of times during a ride. And now the start button does not work. Is it because I ride it under the rain, snow and/or washing it with a sprey jet after each use?
It does not suppose to get effected under bad weather cond.s, so is it because of the pressured water jet?
Even it is, it still sounds not right because it is the only way to clean all that mud.
What am I doing wrong?
How am I going to keep my bike clean and yet still running?
Thanks you all in advance.
Tolga Cilingir
QKENUF4U
236
do all the parts work correclty after drying out for a few days ?? if so then i would find some DIELECTRIC GREASE and lube all teh connections. that will keep the water out. also the pressure washer is prob. causing a lot of your problems. maybe use the pressue washer to get the big clumps off and the garden hose to get the rest off.
good luck
