- Jan 27, 2000
- 6,958
- 45
For those of you doing your own electrical diagnosis, this may help. Note, this theory pertains to mostly British motorcycles but is can also be used to trace electrical problems in other systems.
Electrical Theory by Joseph Lucas.
Positive ground depends on proper circuit functioning, which is the transmission of negative ions by retention of the visible spectral manifestation known as "Smoke".
Smoke is the thing that makes electrical circuits work.
We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing.
For example, if one places a copper bar across the terminals of a battery, prodigious quantities of smoke are liberated and the battery shortly ceases to function.
In addition, if one observes smoke escaping from an electrical component such as a Lucas voltage regulator, it will also be observed that the component no longer functions. The logic is elementary and inescapable!
The function of the wiring harness is to conduct the smoke from one device to another. When the wiring springs a leak and lets all of the smoke out of the system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for some time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, forks and hydraulic brake systems leak fluid, British tires leak air and British Intelligence leak defense secrets.
Therefore, it follows that British electrical systems must leak smoke.
Once again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy in the form of smoke provides a logical explanation of the mysteries of electrical components especially British units manufactured by Joseph Lucas. LTD.
Signed. Joe Lucas. Prince of darkness.
