hoffmannk said:I would also like to drop the size of chain to 420... so I guess i was wondering if anyone knew what spockets will interchange... 13 splines
Especially with a 400 two stroke engine :yikes:mandark1967 said:Why would you want to go to a 420 chain? :yikes:
All you'll do with that setup is cause a chain to snap and rip through your engine case.
hoffmannk said:yes, I looked at it.. at the smallest they make is a 12 tooth.. would REALLY like to find an 11 tooth and that would put me in the ballpark.. do you know if there are any #525 chain 11 tooth sprockets that will fit on a ts 400??
