thumper135
- Sep 20, 2009
- 33
- 0
So the new 62mm piston I installed on my 2 stroke (previous stock piston was a 56mm) is 2mm short in deck height so I had to shave the cylinder base to bring the squish band back to acceptable limits, now that everything is done I noticed that the ports have also gone down in height, can I enlarge the exhaust and intake ports mainly from the top and fill the bottom of the ports with epoxy? or is there something else that you guys can suggest?
