i am trying to tame a 2003 yz85, i have installed a flywheel weight and moved the carb needle to a richer setting, this has helped some but i need to tame it more. someone suggested to me to reduce the ID of the exhaust pipe at the slip joint between the head pipe and the silencer by 25% by welding in a washer. does anyone know if this helps and what are the long term effects to the engine.
