This spring actually replaces a stiffer OEM spring in the high speed adjuster/shim set. Just a different approach, haven't heard of anyone else modifying anything but the base stack.
CLW,
This may have some meerit as generally I've found most high-speed adjusters work better father out. The other maybe wiser thing to do would be to reduce preload on the spring. If the spring is way lighter, then its no good. Anyway I can't say much beyound thoery as I have not worked with that one in specific, I will say that there are other more important issues, and BTW thats the compression adjuster on the shock..... Not the Base-valve, althought in reality they are on in the same.
