There are many many different sizes and types of flywheel pullers. Not all 2-stroke Honda's used the same size. Not all 4-stroke Hondas use the same size. Not all Kawasaki's use the same size.
It will depend on the Kawasaki puller you have and Honda you are wanting to remove a flywheel from. If you check the manual, they might just tell you what size and type of threads you need (I say "might" because I have seen factory manuals that just refer to factory part number and don't give the dimensions).
You can also go online and do a search to find out what type/size of gear puller each bike uses.
