A bolt on flywheel weight is secured and threaded on to where the flywheel nut usually is. With this being said, how accurate is the weight of the bolton flywheel weight? Where as to a weld on flywheel weight, the added weight is actually on the flywheel on the outside of it not like the bolt on model that is threaded onto the crank and is against the flywheel weight.
