Yesterday I helped lower the fork level on a friends bike. It's a '00 YZ. Two things: 1. One fork spring had a coating of rust! How does something rust in an oil bath? Should anything be done? 2. The oil level measured about 95 in both legs, on a fresh oil change is the oil level (after filling the tube all the way to the top to get oil between the inner and outer legs) measured in the same way? Seems I heard that the oil level after a fresh change will measure different as soon as the fork is used. Is there a formula or procedure so we can put the oil level back on a fresh change to wherever we end up after we tune? Does this make sense?
HELP!
HELP!
