Forkspring spacer- or Preload
I just got my new forksprings from Fredette. Along with the springs was a piece of pvc pipe. I called Fredette to find out the use, and he is out of town till next week. The lady with whom I talked with said it was a spacer. OK, but where?
Looked on the parts page on KHI's website, it shows a spacer above the spring(KHI #92143-1645 Fork Collar L=90mm), the one with the washers on top and bottom. When I changed my fork oil the last time, I cleaned this off before re-assembly, and if memory serves me it was metal.
Are you supposed to change the length when you get new springs? Am I even on the right page? If anyone has done this or knows what I am talking about, any information will be greatly appreciated.
Thanks, RJ
p.s. I went to Just KDX and found the preload tip, no picture also. I measured my spring and it was 476.25mm(18.75") not quite 539mm like in the setup tip. Is this what the pvc is for?
Thanks, RJ
