I got my forks back today from MX-tech. I seem to remeber something about snapping a stud off if you tighten the clamp down wrong. Any help would be appriciated, as far to torque specs on the clamps, axle, and axle clamp...
I did do a search, it seems like everyon was breaking them due to over torque. But I seem to remebmer somethign about tightening the top or bottoms ones first that had some effect. Or did everyone snap them from over torque?
You tighten them such that there is NO gap at the top. There will be a gap at the bottom.
Obviously, that means you don't tighten them in a cross pattern, right?
I don't have my manual handy...but I think it's something like 70in/lb. Please do verify that.
It's not a problem doing it 'by hand' (no torque wrench) as long as you have an idea of what force is being applied. If you tend to hamfist stuff...better use a torque wrench.
BTW...(dead thread?**Fixed thanks to michelle..!!** The gist is pasted below anyway.)
If you ever need one of those studs, the Kawasaki part # is 172G0622
They are also reported to have been found at some average hardware stores in the 'metric stud' department. They might be in the 'kdx stud' department, but then......aren't we all?
87 inch pounds for 95 and up. If your scarred, do what i do. I use a 1/4 inch ratchet, choke up on the handle and criss cross like anything else that needs equal pressure thru out. Good luck! Could be wrong tho.
