john pearce
7
Hi all
I have a 2000 KDX220 and running the standard 13/47 size sprockets. However I find that the top speed is not high enough for road use (not without screaming the motor too much).
Can anybody advise if a 14 tooth front sprocket will be OK, so as to lower the top speed revs. I'm hoping that the 14 tooth won't
cause any gearing problems for offroad. I guess I'll just be using 2nd gear instead of the usual 3rd and so on.
Thanks in advance.
John , Portsmouth, England
trigger750
53
hi johon
i have a 1990 kdx200 and i use a 12,13 and 14 tooth sproket on the road 12 is a bit of a handfull at traffic lights
but i normaly use a 13
as for the 14 yes no problems off road i have used for green laneing and have even used one on an enduro with no problems
jeff
