whenfoxforks-ruled said:76 RM250, that bike was set for 20:1 for a good reason.
plynn41 said:Yeah, because oil technology wasn't as good in 1976.
plynn41 said:I've had more than one professional engine tuner (including one who worked for Superbike racer Nicky Haydn) tell me that running too much oil in 2t premix will seize an engine just like running too lean.
I heard the same story about a 95 ford truck tranny! Vintage Bobellandoh said:there was once a man in 1937 who neglected the transmission in his ford austin, so after 70,000 miles he decided to change the trans fluid. needless to say the next day his trans took a hot steamy deuce. to this day if you have neglected your trans for too long you better just leave it alone or every half-arse mechanic WILL warn you your going to be needing a trans TOMORROW
whenfoxforks-ruled said:I heard the same story about a 95 ford truck tranny! Vintage Bob
ellandoh said:it only takes one coincidence to create an urban legend
whenfoxforks-ruled said:Got any proof of this engine seizing due to too much oil? When jetting to more oil, you are naturally going to be going bigger, bigger jets. Its kind of obvious how that got turned around. And you have to remember, a lot of MX bikes came already set to run 20:1. Along comes a misdirected soul with spooge problems and what not. He drops the oil ratio, and thereby is dumping a lot more fuel in. But the rich gas does not foul plugs as easy as the oil does? Its easier to keep the plug hot? Nothing but going the wrong way. Regardless of how many swear by it. Its more they are telling on themselves that they can't, jet, properly maintain it/cheap, or ride it correctly. Take your pick. I did not make it that way. That is just the way it is. So when somebody brings up the old wives tales guess what, that is offensive. Every 4 months. Eric, you are early. Vintage Bob
ellandoh said:i got a 92 f150 bought it with 230000 on it and purposely tested this theory................myth busted. i got 90000 more on it SO FAR.
Eric Kropp said:I teach a lot of youth groups and young welders and use analogies a lot. I presume the transmission comment/description is an analogy....but I can't make the connection. Can you enlighten me?
Eric<><
