Can anyone confirm the 200 from 2002 uses the same piston as the 03-04 models.Wossner lists an aftermaket piston 62.5mm for the 03-04 which is the same diameter as the 02.But are they the same?
Taliesin; the pistons are interchangeable; you might also consider the wiseco 2365M06250(more easily available in the states)- i've used many of these, for several years now, with excellant results./ jack
