Has anyone else used the small washers for making half-clip adjustments? When installed, there is no longer any play in the needle. Normally, you can spin the needle freely in the slide, and there is just a bit of slop.
The concern would be if there is a chance that the needle hangs up due to being snug in the slide. Carb is Keihin 35 PWK.
