Greetings all from Tokyo Japan!
I'm rebuilding the top end on my 95 RMX 250, (S model) it is a re-import from the USA.
I'm looking for the gaskets that Eric Gorr says Cometic makes for my bike. This would be a thinner head gasket (.25 mm, .010 inch) and a thicker cylinder base gasket (1 mm, .039 inch) Mr. Gorr talks about this mod in his Motocross and off road Performance Hand book, to increase the compression and change the port timing.
I cannot find an e-mail address on the Cometic site. The site has some gaskets listed for my RMX, the 2-cycle hi-comp top end gasket kit with a .012" base for the RMX is listed as #C7356. That gives me the Hi-comp head gasket I want, but not the thicker base gasket. I hope some one can provide me with part numbers so I can order these gaskets, as the bike is sitting in pieces now, and I really don't want to put it all back together without this last mod, as everything else is done to the bike, airbox, filter, carb, V-Force reeds, Chamber, silencer, suspension, 17" motard wheels, Oversized rotor etc. This is the last one to do, and everything Mr. Gorr has suggested has worked so well I want to take the opportunity of rebuilding the top end to do this last suggested mod. The guys in Japan have NO IDEA about what I'm talking about.
