Check your wiring for the kill switch and make sure everything is ok there. Next pull off the stator cover and check the timing and gap. You can find that info in a manual if you have one. Thats about the only thing it could be. If everything checks out ok and your still having no spark your looking at replacing your stator or coil. Could even be the cdi box. Good luck
