dirtbikedad
- Mar 24, 2001
- 110
- 0
Help... anyone... My son's 97 CR125 has a reoccuring problem. It is pressurizing the the cooling system, causing the coolant to bypass the new pressure cap and vent through the overflow tube. When the cap is off and the engine running, I see lots of small bubbles rising to the cap inlet. I presume this is due to a blown head gasket. I have changed the gasket, had a machine shop surface the head and cylinder, and carefully torqued the parts together twice. Both times the bike worked for about 5 hours then the problem surfaces.
The cylinder has a steel sleeve that was installed before the first boiling problem.
Can the cylinder have a crack the allows air to get to the water jacket? None are visible.
Any other causes?
Jerry
Any other causes?
Jerry
